[GRASSLIST:3744] Re: v.reclass in GRASS 57
Radim Blazek
blazek at itc.it
Fri Jun 25 03:18:44 EDT 2004
I am not sure if it solves the error, but it should be
where SUBBASIN='Ashokan Reservoir'
instead of
where SUBBASIN="Ashokan Reservoir"
Radim
On Thursday 24 June 2004 22:26, SWlab wrote:
> Hello all,
> I need to dissolve boundaries between polygons sharing a same attribute in
> a huge vector map. I'm trying to use v.reclass in GRASS 5.7.0 (06/17/2004),
> _____
> v.reclass i=WOH_all o=WOH_subbasins type=area rules=./rules.rks field=4
> _____
> where rules.rks is a text file as:
> _____
> cat 101
> cat 102
> where SUBBASIN="Beaver Kill"
> cat 103
> where SUBBASIN="Birch Creek"
> _____
> The command above gives me :
> _____
> dbmi: Protocol error
> ERROR: Cannot select values from database.
> _____
> Though, v.db.connect works nicely (seems so): it detects that WOH_all is
> connected to 4 dbf tables (the map comes from a e00 transformed to coverage
> by avcimport...), proper driver (dbf), proper fields (field i from table
> WOH_all_i.dbf with key=cat), I can display selected areas with d.vect
> correctly...
> ___
> d.vect WOH_all col=blue where="SUBBASIN='Beaver Kill'" field=4
> ___
> Any ideas welcomed. If there's a workaround, I'd be happy with it
> Thanks a lot in advance
