[GRASSLIST:3745] Re: v.reclass in GRASS 57
SWlab
swlab at cornell.edu
Fri Jun 25 04:07:51 EDT 2004
[Friday 25 June 2004 03:18] From Radim Blazek
> I am not sure if it solves the error, but it should be
> where SUBBASIN='Ashokan Reservoir'
> instead of
> where SUBBASIN="Ashokan Reservoir"
Wow... I'm really impressed, it was exactly this ! Single quotes instead of
double quotes ! The reclass rules were written with a pipe to gawk, and I
thought I would avoid escaping single quotes. I'll know better next time.
That solves only part of my problem, though:
1. the boundaries are not dissolved with v.reclass, when they are with
v.extract. I expect 79 new categories (vs the initial 45657...), does this
mean I'm stuck with creating 79 vector maps with v.extract, that I'll have to
merge one way or the other ? What way, BTW ?
2. I end up with this:
_____
WARNING: For 14604 elements no new category was defined
Building topology ...
116779 primitives registered
31131 areas built
992 isles built
Topology was built.
Number of nodes : 86640
Number of primitives: 116779
Number of points : 0
Number of lines : 0
Number of boundaries: 85726
Number of centroids : 31053
Number of areas : 31131
Number of isles : 992
Number of areas without centroid : 78
31053 elments (sic) written
_____
in a nutshell, I'm missing roughly 40% of my expected output map (luckily, not
in the zone I should deal with). The pb may come from the fact that I have to
process a coverage initially e00, that flattened several layers of polygons
and non-boundary lines, plus some non-centroid point features. Top of it, the
'new' v.in.ogr seems to dislike long (more than 10-12 characters) category
names: I end up naturally with several columns sharing the same truncated
name, that I have to edit to get the right value for the right field
(something changed from my march/april version of 5.7...). The initial e00 is
about 100Mb... Any idea ??
Thanks again...
