[GRASSLIST:3770] unable to initialize GDAL bridge
Grant Yip
yip at umail.ucsb.edu
Mon Jun 28 17:24:48 EDT 2004
Hi, I'm a grass beginner and am running into a problem with
r.in.gdal. Whenever I try to import a file, I receive the following error:
GBBridgeInitialize() failed to find an suitable GDAL .DLL/.so file.
The following filenames were searched for:
o libgdal.1.1.so
o gdal.1.0.so
o gdal.so.1.0
o libgdal.so.1
The following locations were searched:
o /usr/local/grass53/lib
o System default locations.
ERROR: Unable to initialize GDAL bridge (check libgdal
installation/LD_LIBRARY_PATH variable).
mail: not found
I am running Grass53 in Cygwin in Windows XP Pro. The version of GDAL that
I built from source is 1.2.1. Thanks in advance.
Grant
Grant Yip
Department of Geological Sciences
Webb Hall - Building 526
University of California
Santa Barbara, CA
93106-9630
(805)893-2782
Grad Shack
<http://www.uweb.ucsb.edu/~yip>www.uweb.ucsb.edu/<http://www.uweb.ucsb.edu/~yip>~yip
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040628/d541ffac/attachment.html
