[GRASSLIST:3773] Re: unable to initialize GDAL bridge
Glynn Clements glynn.clements at virgin.net
Mon Jun 28 19:57:30 EDT 2004
Grant Yip wrote:
> Glynn, I didn't compile Grass53, I installed Grass53 using the binary from
> Rich Greenwood's site.  Is there a solution for the binary install?
No. If r.in.gdal gives that error message, it has been mis-compiled.
> On a side note, I installed Grass53 from binary because I wasn't able to
> compile it from source.  The './cofigure' command worked fine but was never
> able use the 'make' command.  I just received an error stating that there
> was nothing to make.
Odd. What does the Makefile look like?
Glynn Clements <glynn.clements at virgin.net>
