[GRASSLIST:3774] Re: unable to initialize GDAL bridge
Grant Yip yip at umail.ucsb.edu
Mon Jun 28 22:16:13 EDT 2004
At 04:57 PM 6/28/2004, Glynn Clements wrote:
>Odd. What does the Makefile look like?
Actually, it wouldn't make it past './configure'.  the program goes through
a series of 'checking for...' messages and stops at the following message
'configure: error: ***Unable to locate ODBC library' at which time it jumps
to the command prompt.  I cannot go any further at this point and cannot
enter the make or make install commands..
I have the required libraries listed on the GRASS REQUIREMENTS page,
including unixodbc2, which I guess is the ODBC library the program cannot
find.  Do you have any suggestions for getting around this error so that I
can compile from source?
Grant
Grant Yip
Department of Geological Sciences
Webb Hall - Building 526
University of California
Santa Barbara, CA
93106-9630
(805)893-2782
Grad Shack
<http://www.uweb.ucsb.edu/~yip>www.uweb.ucsb.edu/<http://www.uweb.ucsb.edu/~yip>~yip
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040628/6816e5b7/attachment.html
