[GRASSLIST:3776] Re: unable to initialize GDAL bridge
Glynn Clements
glynn.clements at virgin.net
Tue Jun 29 01:36:22 EDT 2004
Grant Yip wrote:
> >Odd. What does the Makefile look like?
> Actually, it wouldn't make it past './configure'. the program goes through
> a series of 'checking for...' messages and stops at the following message
> 'configure: error: ***Unable to locate ODBC library' at which time it jumps
> to the command prompt. I cannot go any further at this point and cannot
> enter the make or make install commands..
> I have the required libraries listed on the GRASS REQUIREMENTS page,
> including unixodbc2, which I guess is the ODBC library the program cannot
> find. Do you have any suggestions for getting around this error so that I
> can compile from source?
Use --without-odbc to disable the ODBC checks and the programs which
use ODBC (none of which are particularly important).
Glynn Clements <glynn.clements at virgin.net>
