[GRASSLIST:3790] Re: PNG driver
SWlab
swlab at cornell.edu
Wed Jun 30 09:37:22 EDT 2004
> - vectors and the parts of rasters with black color are not drew on the PNG
> file
Likely to be a transparency problem: have you checked the values of
GRASS_BACKGROUNDCOLOR and GRASS_TRANSPARENT ?
> - i can not set the width of the vectors.
I don't think you can change the width of vectors with d.vect in GRASS53. Try
GRASS57, or use ps.map to get an EPS you can convert to PNG with gimp or
Imagemagick
