[GRASSLIST:2848] Re: import raster
Markus Neteler
neteler at itc.it
Fri Mar 5 05:07:23 EST 2004
On Thu, Mar 04, 2004 at 04:55:44PM +0100, Daniele Scarselli wrote:
> Hi,
> I've a problem importing some raster:
> I use r.in.gdal to import a raster and the results are files over 100 mb for
> every raster.
> With r.compress I reduce to 17,4 mb.
> Is there a method to reduce again these files?
> I think that GRASS take the raster as a 8 bit image while the original is
> black and white (1 bit)
> thanks
> Daniele Scarselli
The code portion in question will be (main.c from r.in.gdal):
switch(eRawGDT) {
case GDT_Float32:
case GDT_Float64:
data_type = FCELL_TYPE;
eGDT = GDT_Float32;
complex = FALSE;
break;
case GDT_Byte:
data_type = CELL_TYPE;
eGDT = GDT_Int32;
complex = FALSE;
G_set_cell_format(0);
raster_open_new_func = G_open_raster_new_uncompressed;
break;
case GDT_Int16:
case GDT_UInt16:
eGDT = GDT_Int32;
complex = FALSE;
G_set_cell_format(1);
break;
default:
eGDT = GDT_Int32;
complex = FALSE;
G_set_cell_format(3);
break;
Anything to improve there?
switch(eRawGDT) {
case GDT_Float32:
case GDT_Float64:
eGDT = GDT_Float32;
complex = FALSE;
break;
case GDT_Byte:
eGDT = GDT_Int32;
complex = FALSE;
break;
case GDT_Int16:
case GDT_UInt16:
eGDT = GDT_Int32;
complex = FALSE;
break;
default:
eGDT = GDT_Int32;
complex = FALSE;
break;
switch(eRawGDT) {
case GDT_Float32:
case GDT_Float64:
eGDT = GDT_Float32;
complex = FALSE;
break;
case GDT_Byte:
eGDT = GDT_Int32;
complex = FALSE;
break;
case GDT_Int16:
case GDT_UInt16:
eGDT = GDT_Int32;
complex = FALSE;
break;
default:
eGDT = GDT_Int32;
complex = FALSE;
break;
GDAL provides:
./gcore/gdal.h
/*! Pixel data types */
typedef enum {
GDT_Unknown = 0,
/*! Eight bit unsigned integer */ GDT_Byte = 1,
/*! Sixteen bit unsigned integer */ GDT_UInt16 = 2,
/*! Sixteen bit signed integer */ GDT_Int16 = 3,
/*! Thirty two bit unsigned integer */ GDT_UInt32 = 4,
/*! Thirty two bit signed integer */ GDT_Int32 = 5,
/*! Thirty two bit floating point */ GDT_Float32 = 6,
/*! Sixty four bit floating point */ GDT_Float64 = 7,
/*! Complex Int16 */ GDT_CInt16 = 8,
/*! Complex Int32 */ GDT_CInt32 = 9,
/*! Complex Float32 */ GDT_CFloat32 = 10,
/*! Complex Float64 */ GDT_CFloat64 = 11,
GDT_TypeCount = 12 /* maximum type # + 1 */
} GDALDataType;
Anything to improve in r.in.gdal (we all like small files)?
Markus
