[GRASSLIST:2852] Re: import raster
Glynn Clements
glynn.clements at virgin.net
Fri Mar 5 12:58:43 EST 2004
Markus Neteler wrote:
> > I've a problem importing some raster:
> > I use r.in.gdal to import a raster and the results are files over 100 mb for
> > every raster.
> > With r.compress I reduce to 17,4 mb.
> > Is there a method to reduce again these files?
> > I think that GRASS take the raster as a 8 bit image while the original is
> > black and white (1 bit)
> Anything to improve in r.in.gdal (we all like small files)?
If the file is being compressed, the underlying format (1/2/4 bytes)
won't make much difference.
The only way to get any significant reduction in the file sizes would
be to use zlib (or similar) rather than RLE compression.
Glynn Clements <glynn.clements at virgin.net>
