[GRASSLIST:2880] text
Bettina
Bebird at gmx.net
Tue Mar 9 06:49:19 EST 2004
Hi
Still the same problem: I would like to insert a dxf-file in GRASS GIS
5.0.3.
I have loaded the "Layer with Line data" via v.in.dxf, which I can see on
the monitor.
How I can load layers with texts from a dxf file. At the moment, I can
just see contour lines.
How can I make the text visible?
And houw does it work in GRASS 5.7?
Thank you for your help
Bettina
+++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++
100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
