[GRASSLIST:2882] Re: v.what.rast bug?
Christopher Fonnesbeck
chris at fonnesbeck.org
Tue Mar 9 10:11:38 EST 2004
On Mar 9, 2004, at 3:13 AM, Radim Blazek wrote:
>> I have tried running v.segment directly on my stream network, and I
>> get
>> the same behaviour; that is, the process hangs without using any CPU.
>> If I press enter, I get the incorrect segment type warning repeatedly.
>> I eventually have to kill the process.
>> What I am trying to do now is determine the downstream polyline of
>> each
>> polyline in a stream network. I assume I need to run v.segment first,
>> then do some programming?
> What is your input you send to stdin of v.segment?
To stdin? I thought the input was specified by the "input=" option. Do
you mean that input needs to be piped to v.segment?
Thanks,
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
