[GRASSLIST:2885] Re: r.in.bin and 8 bit (unsigned) binary
Glynn Clements
glynn.clements at virgin.net
Tue Mar 9 11:42:32 EST 2004
Martin du Saire wrote:
> > So I managed to import the data using r.in.bin with r=8996, c=9223, and am
> > > currently messing around with r.support to get the output I want. However,
> > > there is a mismatch between the actual (81,026kb) and calculated file size
> > > (based on row x cols: 82,970kb). What does this mean?
The mismatch is due to the difference between 1000 bytes and a
kilobyte (1024 bytes):
8996 * 9223 = 82970108 bytes.
82970108 / 1000 = 82970
82970108 / 1024 = 81025
Glynn Clements <glynn.clements at virgin.net>
