[GRASSLIST:2893] g.region ellipsoid info
Martin du Saire mdusaire at UMN.EDU
Wed Mar 10 11:12:03 EST 2004
I used g.setproj to adjust the ellipsoid info for my laea projection.  The
new ellipsoid info was: sphere:6370997, but g.region -p shows
ellipsoid: **unknown (default: WGS84)**
even though when I run g.setproj a second time the sphere info comes up as
the current settings.  Is everything okay, or should I re-define the
LOCATION from scratch?
Thanks.
Martin
