[GRASSLIST:2896] Re: g.region ellipsoid info
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Mar 10 15:19:42 EST 2004
On Wed, 10 Mar 2004, Martin du Saire wrote:
> Hi,
> I used g.setproj to adjust the ellipsoid info for my laea projection. The
> new ellipsoid info was: sphere:6370997, but g.region -p shows
> ellipsoid: **unknown (default: WGS84)**
Don't worry about what g.region says. It should not really be reporting
the ellipsoid as it isn't relevant to the region settings.
Are you using the latest 5.3? I think I fixed some bugs
(e.g. it said the ellipsoid was unknown if there was no ellps line in the
PROJ_INFO when it is quite acceptable for it to be defined by the
underlying a, es etc. parameters)
> even though when I run g.setproj a second time the sphere info comes up as
> the current settings. Is everything okay, or should I re-define the
> LOCATION from scratch?
If you post the output of g.projinfo here we can see if it is valid or not.
What modules are you using where the ellipsoid being a sphere might be
important? (converting to lat/long or reprojecting?) I don't think sphere
was handled very well in most 5.0.x versions---you may be better using 5.3
if necessary but I'm not 100% sure that everything that accepts a sphere
does so.
The main reason it was important was for people working with Mars but I
don't think I have seen any feedback from them about the bugfixes.
