[GRASSLIST:2922] Re: multiple installs of GRASS
Richard Greenwood
rich at greenwoodmap.com
Fri Mar 12 10:08:53 EST 2004
Martin du Saire wrote:
> Hi,
> Can I have two versions of GRASS (5.0 and 5.3) installed at the same
> time, and if not, will GRASS5.3 simply overwrite 5.0 or do I need to
> uninstall somehow. I am planning on trying the 5.3 binary provided by
> R. Greenwood since I have no idea how to compile the sources.
> Thanks.
> Martin
It should not be a problem. By default, it will install into
/usr/local/grass53. You can start it with "grass53". "grass5" will still
launch your current version of grass.
Regards,
Rich
Richard Greenwood
www.greenwoodmap.com
