[GRASSLIST:2926] Re: multiple installs of GRASS
Martin du Saire
mdusaire at umn.edu
Fri Mar 12 17:00:21 EST 2004
Have 5.3 up and running, and I have even figured out the GUI (nice), but is
there some way to also use the command-line from within the GUI. For
example I cannot set the -z flag in r.patch?
Martin
At 08:08 AM 3/12/2004 -0700, you wrote:
>Martin du Saire wrote:
>>Hi,
>>Can I have two versions of GRASS (5.0 and 5.3) installed at the same
>>time, and if not, will GRASS5.3 simply overwrite 5.0 or do I need to
>>uninstall somehow. I am planning on trying the 5.3 binary provided by R.
>>Greenwood since I have no idea how to compile the sources.
>>Thanks.
>>Martin
>It should not be a problem. By default, it will install into
>/usr/local/grass53. You can start it with "grass53". "grass5" will still
>launch your current version of grass.
>Regards,
>Rich
>Richard Greenwood
>www.greenwoodmap.com
