[GRASSLIST:2931] Re: multiple installs of GRASS
Richard Greenwood
rich at greenwoodmap.com
Sat Mar 13 09:04:36 EST 2004
Martin du Saire wrote:
> Have 5.3 up and running, and I have even figured out the GUI (nice), but
> is there some way to also use the command-line from within the GUI. For
> example I cannot set the -z flag in r.patch?
> Martin
If you start the GUI with "tcltkgrass&" or "tcltkgrass &" then you
should be able to enter grass commands. The key is to put the "&" at the
end of tcltkgrass command. This causes tcltkgrass to be launched but
tells the shell not to wait for it to finish.
Richard Greenwood
www.greenwoodmap.com
