[GRASSLIST:2979] NViz: command not found
Matthew Tennant
Matthew.Tennant at MobileInnovation.co.uk
Thu Mar 18 11:38:04 EST 2004
Hello Grasslist.
I have a problem - occuring on the Windows port of GRASS
(5.0.2) using the cygwin
environment and XWindows driver. When I type nviz at the command prompt I
get a "command not found" message.
Searching my cygwin tree I see I only have one file called nviz, in
usr/local/grass5/tcktkgrass/module, and it's only 1K.
Does this mean I haven't installed nviz? If not how do I? Is it possible
to install binaries only, or is compilation of source necessary?
thanks,
Matt
