[GRASSLIST:3013] Re: r.mapcalc
Pierluigi De Rosa
sisma66 at tiscali.it
Tue Mar 23 09:58:17 EST 2004
this is the output of gmake53 on directory r.mapcalc3...
SRC = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src
CMD = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/CMD
UNUSED = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE =
/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/dist.i686-pc-linux-gnu
VERSION = 5.3-cvs 2004
/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/raster/r.mapcalc3
make -f OBJ.i686-pc-linux-gnu/make.rules
bison -y -d mapcalc.y
make: *** [y.tab.c] Broken pipe
Can you help me?? now both (r.mapcalc and r.mapcalc3) doesn't works!!!
> > I'm using grass5.3 cvs and after compiling I haven't command r.mapcalc...
> > so I want to compile single module but I have this error in gmake
> > make[1]: Entering directory
> > `/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/raster/r.ma
> >pcalc/polish'
> Wrong directory.
> > gcc
> > -I/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/include -g
> > -O2 -c main.c -o OBJ.i686-pc-linux-gnu/main.o
> > bison -y -d pol.y
> > conflicts: 14 shift/reduce, 17 reduce/reduce
> > make[1]: *** [y.tab.c] Broken pipe
> > make[1]: Leaving directory
> >pcalc/polish' make: *** [all] Error 1
> > P.S. I noticed there is a file "deprecated" in directory r.mapcalc and it
> > sayd that now the new one is r.mapcalc3...
> Yes. Use gmake5 on src/raster/r.mapcalc3 instead.
> > How know anythink???
> > this below is my last row of command make...
> > GISBASE=/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/dist.i68
> >6-pc-linux-gnu MACHINENAME=`uname -n`
> > SRCDIR=/home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13 /bin/sh
> > src/CMD/generic/POST_INSTALL.sh i686-pc-linux-gnu
> > GRASS GIS source code compiled.
> > Compilation error in module: src/raster/r.binfer (ignored)
> > Compilation error in module: src/raster/r.combine (ignored)
> > Compilation error in module: src/raster/r.mapcalc3 (ignored)
> That's the "real" r.mapcalc. I would need to see the actual error
> messages in order to know why it failed.
