[GRASSLIST:3022] Re: r.mapcalc
Glynn Clements
glynn.clements at virgin.net
Tue Mar 23 16:03:48 EST 2004
Pierluigi De Rosa wrote:
> this is the output of gmake53 on directory r.mapcalc3...
> SRC = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src
> CMD = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/CMD
> UNUSED = /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/unused
> HEADER = head.i686-pc-linux-gnu
> ARCH = i686-pc-linux-gnu
> GISBASE =
> /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/dist.i686-pc-linux-gnu
> VERSION = 5.3-cvs 2004
> /home/ivan/Documents/grass5.3_CVS/grass53_exp_2004_03_13/src/raster/r.mapcalc3
> make -f OBJ.i686-pc-linux-gnu/make.rules
> bison -y -d mapcalc.y
> make: *** [y.tab.c] Broken pipe
> Can you help me?? now both (r.mapcalc and r.mapcalc3) doesn't works!!!
I can only presume that something is wrong with your copy of bison.
Looking back at your original email, I note:
Compilation error in module: src/raster/r.binfer (ignored)
Compilation error in module: src/raster/r.combine (ignored)
Compilation error in module: src/raster/r.mapcalc3 (ignored)
Compilation error in module: src/raster/r.weight (ignored)
Compilation error in module: src.contrib/GMSL/g3d (ignored)
This is the exact set of modules which use bison (or yacc), so I
strongly suspect that your bison program doesn't work.
Glynn Clements <glynn.clements at virgin.net>
