[GRASSLIST:3032] Re: v.extract without centroids
Radim Blazek
blazek at itc.it
Fri Mar 26 03:13:29 EST 2004
On Thursday 25 March 2004 13:36, Otto Dassau wrote:
> Dear list,
> I have two questions:
> 1) I imported an area shape with 6000 polygons in g57 and
> there are 2 centroids missing. How can I find these two
> centroids?
I believe that those 2 areas without centroids are slivers between
shape polygons.
> 2) I used v.extract on this shape (with the 2 missing centroids).
> v.extract in=SHAPE out=SHAPE2 type=area where='AREAQM>1'.
Try type=area,centroid. This is not correct and it should be fixed,
type=area must export also centroids.
Radim
> The areas geometry is extracted correctly but now all without centroid.
> Is this because there were 2 missing in the beginning?
> SHAPE
> Number of nodes : 12171
> Number of primitives: 15470
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 10777
> Number of centroids : 4693
> Number of areas : 4695
> Number of isles : 1396
> Number of areas without centroid : 2
> SHAPE2 after using v.extract:
> Number of nodes : 6602
> Number of primitives: 7529
> Number of lines : 0
> Number of boundaries: 7529
> Number of centroids : 0
> Number of areas : 2300
> Number of isles : 1373
> Number of areas without centroid : 2300
> thanks for help
> Otto
