[GRASSLIST:3034] Re: v.extract without centroids
Otto Dassau
otto.dassau at gmx.de
Fri Mar 26 07:47:39 EST 2004
Radim Blazek schrieb:
> On Thursday 25 March 2004 13:36, Otto Dassau wrote:
> > Dear list,
> > I have two questions:
> > 1) I imported an area shape with 6000 polygons in g57 and
> > there are 2 centroids missing. How can I find these two
> > centroids?
> I believe that those 2 areas without centroids are slivers between
> shape polygons.
> > 2) I used v.extract on this shape (with the 2 missing centroids).
> > v.extract in=SHAPE out=SHAPE2 type=area where='AREAQM>1'.
> Try type=area,centroid. This is not correct and it should be fixed,
> type=area must export also centroids.
Hi Radim,
thank you for your hint:
I used:
v.extract in=SHAPE out=SHAPE2 type=area,centroid where='AREAQM>1'.
it exports areas _and_ the centroids, but now _all_ areas,
although I just want to export areas > 1 with centroid.
Number of nodes : 6765
Number of primitives: 7692
Number of points : 0
Number of lines : 0
Number of boundaries: 7529
Number of centroids : 163
Number of areas : 2300 -> should be 163 !
Number of isles : 1373
Number of areas without centroid : 2137
What can be done to solve this?
thank you
Otto
