[GRASSLIST:3366] Re: r.mapcalc syntax
Glynn Clements
glynn.clements at virgin.net
Thu May 6 17:42:51 EDT 2004
Ulrich Leopold wrote:
> I am using the following command and get an parse error expecting ")"
> r.mapcalc Errors="if('VAL.stone.lsk_OK.DIFF_SQRT_VAR' < -2,
> ('500.Pox0t30.STONE' - ('Pox0t30_OK_block.pred.LSK' - (2 *
> (sqrt('Pox0t30_OK_block.var.LSK')))/('500.Pox0t30.STONE') * -100),
> null() ))"
> parse error, expecting ")"
> Parse error
> What am I doing wrong. I checked the position of the parenthesis. But I
> cannot figure out where a parenthesis is missing. The similar command
> works in the statistics package 'R'.
First, I'll replace the map names by X to make the structure more
clear:
if(X < -2, (X - (X - (2 * (sqrt(X)))/(X) * -100), null() ))
Look at the nesting of the parentheses:
This expression has the form:
if(A, (B, C))
where:
A == X < -2
B == X - (X - (2 * (sqrt(X)))/(X) * -100)
C == null()
However, (B,C) isn't a valid expression. You probably wanted to omit
the parentheses to give:
if(A, B, C)
which is valid.
So, your command should probably be:
null())"
Regarding the reason why the error message says "expecting ')'":
When the parser gets to:
if(A, (B,
it can't parse the comma, because a comma is only valid within a
function's argument list. However, if there had been a closing
parenthesis before the comma, it would have:
if(A, (B),
The comma would be part of the argument list for if(), and so would be
valid. Hence the "expecting ')'" message.
Glynn Clements <glynn.clements at virgin.net>
