[GRASSLIST:3385] Re: Compile Error-Tcl Problem?
Mon May 10 23:57:15 EDT 2004
> I'm trying to build Grass 5.7 from cvs on a newly installed debian
> sarge i386 system. I may still be missing some pieces of the puzzle,
> since this is the first attempted build of anything on this system,
> and I had to install a number of  *-dev and other packages to get
> through ./configure. For Tcl, I have installed packages:
GRASS 5.0.3 req'd Debian/testing packages, Jan 22, 2004
gcc              # for compile
libc6-dev        # for basics
flex             # for lex
bison            # for yacc
libncurses5-dev  # for curses
zlib1g-dev       # zlib
libreadline4-dev # readline
libjpeg62-dev  or  libjpeg-mmx-dev  # for JPEG support
libtiff3g-dev    # for TIFF support
libpng12-dev     # for PNG support
libgd2-xpm-dev   # for GD 2.0 install
libg2-dev        # for GD 2.0  (unneed for GRASS > 5.0.x)
tcl8.3-dev       # for TCL
tk8.3-dev        # for TK
postgresql       # for Postgresql support ???
postgresql-dev   # for Postgresql support ???
xlibmesa-gl-dev  # for OpenGL
libstdc++5-3.3-dev # for glu-dev
xlibmesa-glu-dev # for OpenGL
unixodbc-dev     # for ODBC
fftw-dev         # for FFT functions
lesstif2-dev     # for Motif
libgdal1-dev     # for GDAL
libfreetype6-dev # for Freetype Fonts (broken)
make             # won't get far without this..
g++              # for r.terraflow
optional:
gdal-bin         # for GDAL (doesn't include libraries or gdal-config)
proj             # for PROJ.4
Configure 5.0.3 with:
CFLAGS="-O3 -march=i686 -Wall" LDFLAGS="-s" ./configure \
        --with-tcltk-includes=/usr/include/tcl8.3 \
        --with-postgres-includes=/usr/include/postgresql \
        --with-motif --with-motif-includes=/usr/X11R6/include \
        --with-freetype --with-freetype-includes=/usr/include/freetype2 \
        --with-glw --with-readline --with-gdal \
        2>&1 | tee config_log.txt
GRASS 5.7:
get latest CVS version of GRASS 5.3  (to /usr/src/grass/grass53)
get latest CVS version of GRASS 5.7  (to /usr/src/grass/grass57)
Then use:
./configure \
    --with-grass50=/usr/src/grass/grass53 \
    --with-readline --with-gdal --with-cxx --with-glw \
    --with-proj
make mix
make
To run GRASS 5.7, simply start
./bin.$ARCH/grass57
> I know that there is a 5.03 binary package for debian. I installed it,
> but it threw the infamous NVIZ segfault.
You need to install against Tcl/Tk 8.3. Install the tcl8.3-dev and
tk8.3-dev packages.
This is Debian bug #248105
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=248105
Hamish
