[GRASSLIST:3391] Re: Compile Error-Tcl Problem?
    Carl Brown
    cbsled at ncia.net
    Tue May 11 09:44:14 EDT 2004
On Tuesday 11 May 2004 3:43 am, Glynn Clements wrote:
> AFAIK, that code requires Tcl/Tk 8.4
It looks like you are correct.
I built it using (mostly) Hamish's ./configure line, which specifies 8.3. It
built successfully while I slept, or at least it did not terminate with an
error.  On running it, I find that directory /usr/local/grass57/tcltkgrass
does not exist.
I'll try again...
Carl Brown
Whitefield, NH USA
