[GRASSLIST:3448] Re: r.in.gdal
Guillermo Felipe
gfmb at tutopia.com
Thu May 20 02:00:54 EDT 2004
Hello Marta
AFIK, probably your region settings don't are equal to your dem projection.
You can check what region you have with the command g.region.
Maybe you can use:
r.in.gdal -oe input=/usr/local/marta/sud.dem output=sud_dem.rast
the flags -eo means yes to the questions :
Override projection (use locations projection)?
and
Extend location extents based on new dataset.?
Have a nice day,
Guillermo
El Jue 20 May 2004 14:26, Marta Della Seta escribió:
> I'm trying to import .dem files (I have the grass5.0.3 version), but a
> segmentation fault occurs:
> GRASS:~ > r.in.gdal
> OPTION: Bin raster file to be imported
> key: input
> required: YES
> enter option > /usr/local/marta/sud.dem
> You have chosen:
> Is this correct? (y/n) [y]
> OPTION: Band to select (default is all bands)
> key: band
> required: NO
> enter option >
> OPTION: Name for resultant raster map
> key: output
> required: YES
> Enter raster file name
> Enter 'list' for a list of existing raster files
> Hit RETURN to cancel request
> > sud_dem.rast
> <sud_dem.rast>
> OPTION: Name of location to read projection from for GCPs
> transformation
> key: target
> required: NO
> enter option >
> OPTION: Title for resultant raster map
> key: title
> format: "phrase"
> required: NO
> enter option >
> OPTION: Name for new location to create
> key: location
> required: NO
> enter option >
> FLAG: Set the following flag?
> Override projection (use locations projection)?(y/n) [n]
> Extend location extents based on new dataset.?(y/n) [n]
> Segmentation fault
> So I tried processing this DEM with the commandline GDAL utilities
> instead of the GRASS r.in.gdal command, and in this way it seems working
> fine (I have GDAL 1.2.0):
> [root at geomorf2 root]# gdalinfo -mm /usr/local/marta/sud.dem
> Driver: USGSDEM/USGS Optional ASCII DEM
> Size is 935, 1250
> Coordinate System is:
> PROJCS["UTM Zone 33, Northern Hemisphere",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AXIS["Lat",NORTH],
> AXIS["Long",EAST],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",15],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0]]
> Origin = (334305.000000,4762665.000000)
> Pixel Size = (90.00000000,-90.00000000)
> Corner Coordinates:
> Upper Left ( 334305.000, 4762665.000)
> Lower Left ( 334305.000, 4650165.000)
> Upper Right ( 418455.000, 4762665.000)
> Lower Right ( 418455.000, 4650165.000)
> Center ( 376380.000, 4706415.000)
> Band 1 Block=935x1250 Type=Float32, ColorInterp=Undefined
> Computed Min/Max=-27.000,2847.900
> NoData Value=-32767
> Unit Type: m
> Could someone help me?!?!?
> marta
