[GRASSLIST:3447] r.in.gdal
    Marta Della Seta
    marta.dellaseta at uniroma1.it
    Thu May 20 08:26:58 EDT 2004
I'm trying to import .dem files (I have the grass5.0.3 version), but a
segmentation fault occurs:
        GRASS:~ > r.in.gdal
        OPTION:   Bin raster file to be imported
             key: input
        required: YES
        enter option > /usr/local/marta/sud.dem
        You have chosen:
          input=/usr/local/marta/sud.dem
        Is this correct? (y/n) [y]
        OPTION:   Band to select (default is all bands)
             key: band
        required: NO
        enter option >
        OPTION:   Name for resultant raster map
             key: output
        required: YES
        Enter raster file name
        Enter 'list' for a list of existing raster files
        Hit RETURN to cancel request
        > sud_dem.rast
        <sud_dem.rast>
        OPTION:   Name of location to read projection from for GCPs
        transformation
             key: target
        required: NO
        enter option >
        OPTION:   Title for resultant raster map
             key: title
          format: "phrase"
        required: NO
        enter option >
        OPTION:   Name for new location to create
             key: location
        required: NO
        enter option >
        FLAG: Set the following flag?
            Override projection (use locations projection)?(y/n) [n]
            Extend location extents based on new dataset.?(y/n) [n]
        Segmentation fault
So I tried processing this DEM with the commandline GDAL utilities
instead of the GRASS r.in.gdal command, and in this way it seems working
fine (I have GDAL 1.2.0):
        [root at geomorf2 root]# gdalinfo -mm /usr/local/marta/sud.dem
        Driver: USGSDEM/USGS Optional ASCII DEM
        Size is 935, 1250
        Coordinate System is:
        PROJCS["UTM Zone 33, Northern Hemisphere",
            GEOGCS["WGS 84",
                DATUM["WGS_1984",
                    SPHEROID["WGS 84",6378137,298.257223563,
                        AUTHORITY["EPSG","7030"]],
                    TOWGS84[0,0,0,0,0,0,0],
                    AUTHORITY["EPSG","6326"]],
                PRIMEM["Greenwich",0,
                    AUTHORITY["EPSG","8901"]],
                UNIT["degree",0.0174532925199433,
                    AUTHORITY["EPSG","9108"]],
                AXIS["Lat",NORTH],
                AXIS["Long",EAST],
                AUTHORITY["EPSG","4326"]],
            PROJECTION["Transverse_Mercator"],
            PARAMETER["latitude_of_origin",0],
            PARAMETER["central_meridian",15],
            PARAMETER["scale_factor",0.9996],
            PARAMETER["false_easting",500000],
            PARAMETER["false_northing",0]]
        Origin = (334305.000000,4762665.000000)
        Pixel Size = (90.00000000,-90.00000000)
        Corner Coordinates:
        Upper Left  (  334305.000, 4762665.000)
        Lower Left  (  334305.000, 4650165.000)
        Upper Right (  418455.000, 4762665.000)
        Lower Right (  418455.000, 4650165.000)
        Center      (  376380.000, 4706415.000)
        Band 1 Block=935x1250 Type=Float32, ColorInterp=Undefined
            Computed Min/Max=-27.000,2847.900
          NoData Value=-32767
          Unit Type: m
Could someone help me?!?!?
marta
