[GRASSLIST:3472] Re: v.cutter
    Luis Gonçalves Seco
    luis at novalis.web.pt
    Mon May 24 05:18:49 EDT 2004
Hi Radim,
Thanks, but i´m using the 5.03 version. There are no other way?
Regards,
Luis Gonçalves Seco
-----Mensagem original-----
De: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] Em nome
de Radim Blazek
Enviada: segunda-feira, 24 de Maio de 2004 9:21
Para: Luis Gonçalves Seco; grasslist at baylor.edu
Assunto: [GRASSLIST:3470] Re: v.cutter
On Saturday 22 May 2004 23:47, Luis Gonçalves Seco wrote:
> Hi,
> I whould like to know how can i do this:
> Suppose I have a mount (vector) that belong to a city(vector), but the
> mount area it exceeds is border. If i use v.cutter the result will be the
> inside part of the interseption, no?. But I want to know how I can obtain
> only the part that don´t belong to the city area (outside part). In raster
> mode I can do that, but I need that in vector mode. Probably if I used the
> result of the v.cutter then make v.patch with the mount vector and finally
> with v.extrat I will obtain the result. There is an easy and logic way to
> do this?
v.overlay operator=not (5.7)
Radim
