[GRASSLIST:3555] Re: which version should be used?
Martin Wegmann
mailinglist2_wegmann at web.de
Mon May 31 10:54:15 EDT 2004
On Monday 31 May 2004 13:04, Anja Drews wrote:
> Dear list,
> thank you very much for your help.
> I will start with version 5.3.
> Martin wrote that it is possible to install both versions on my system.
> How must the structure look like with the old and the new programm on one
> computer? I don't want both systems to get confused by each other -even if
> they use the same database.
Which operating system are you using? Under Linux you just install both
version and start GRASS 5.0.x with the command "grass5" and the 5.7.0 version
with "grass57" in the shell. Not later "refinement" of the structure is
necessary.
I am not aware that two different GRASS version get confused with each other -
perhaps somebody else can tell you that they definitely can access the same
database (not at the same time) without producing errors.
I am running 5.0.3 and 5.7.0 and both are accessing the same db - so far
without errors.
> And right now I cannot do any experiments on the servers.
sorry, not experiences with server based GRASS functionalities.
> In the future, when the stable version 5.4. is released is it possible to
> plug in and plug out the new and old GRASS version without a complete new
> installation?
well, I doubt that there will be some kinds of "upgrade" functions available -
you have to go through the whole installation process again.
But that is not a big deal if you are using the binaries for Linux, just do
"sh name_of_shell_script.sh name_of_GRASS_tar.gz" -- done.
> I planned the whole system a chain of modules. For an update I do not want
> to install everything all over again.
If you are not in a hurry, wait a couple of .... days? or weeks ... and 5.4.0
will be released, than you don't have to worry about a second installation
until the 5.7.0 branch releases a stable version ;-)
regards, Martin
> > Hello Anja,
> > On Friday 28 May 2004 17:18, Anja Drews wrote:
> >> Dear list,
> >> I would like to integrate GRASS at the end of our (nearly or in the near
> >> future) operational running processing chain of Meteosat-7 and
> >> Meteosat-8 data. Which GRASS version would you suggest for an
> >> application like this? The stable version 5.02/3 or the test version 5.3
> >> which might have more features that could be useful for meteorological
> >> data analyses? I have nearly no expierience with GRASS. I used other GIS
> > 5.3.0 is testing but soon will become stable 5.4.0. So if you wait some
> > time
> > you can go straight to the new stable rather than using a possibly buggy
> > version - but nevertheless 5.3.0 is in my experiences reliable enough for
> > daily usage. And if you encounter a bug, please report it and it will
> > soon
> > be fixed in the 5.4.0 version.
> > BTW you can install both GRASS version on your system and use both for
> > the same database. If 5.0.3 lacks features you need, just start 5.3.0 and
> > give it
> > a try - if this one is too buggy for your purpose swap back to 5.0.3.
> >> packages before and so I am still a GRASS greenhorn. So I have no idea
> >> how evident the differences between 5.0 and 5.3 are.
> > have a look at the announcement
> > http://grass.itc.it/announces/announce_grass530.html
> > Unfortunately I am not experienced in meteorological data analysis hence
> > I have no idea which GRASS modules might be useful.
> > hope you enjoy GRASS, regards Martin
