[GRASSLIST:4717] Re: ps.map segmentation fault
marta.benito at uam.es
Fri Nov 5 16:35:47 EST 2004
Hello,
please forget the last mail, ps.map works fine, but i am having problems with
vectors:
d.vect aalba
segmentation fault
an so on with other commands.
I have tried to recompiled GRASS, and the compilation seems OK, but some vector
commands donot work.
what should I change ??
thank you
marta
> Hello,
> I am trying to use ps.map (GRASS57) but I obtained :
> GRASS 5.7.cvs:~/grassdata/espanya_modelo_devel > ps.map
> input=prob.post.present.ppinea.rf.gen output=prueba
> Segmentation fault
> The file prob.post.present.ppinea.rf.gen:
> raster prob.present.rf.cut at pred_ppinea
> vareas contpen_present at especies
> fcolor none
> end
> paper
> width 11.15
> height 9.3
> right 0
> left 0
> bottom 0
> top 0
> end
> end
> If I use it in another computer (same version) it works perfectly.
> Thank you in advance
> marta
> Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
> ------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
