[GRASSLIST:4723] Re: ps.map segmentation fault
Radim Blazek blazek at itc.it
Sat Nov 6 03:45:44 EST 2004
marta.benito at uam.es wrote:
> Hello,
> please forget the last mail, ps.map works fine, but i am having problems with
> vectors:
>  d.vect aalba
>  segmentation fault
> an so on with other commands.
> I have tried to recompiled GRASS, and the compilation seems OK, but some vector
> commands donot work.
- Do you have enough space on disk?
- Which module was used to write the vector,
   finished without error?
- GRASS was compiled on the same computer?
- What files (ls -l) are in the vectors directory
   ($MAPSET/vector/aalba)?
- Does it help to run v.build?
- The same vector vector works on other computer?
- Set debug level: g.gisenv set=DEBUG=5, run the d.vect again,
   and send the last 50 rows to this list.
Radim
