[GRASSLIST:4742] Re: v.in.ogr gives dbmi: db_open_database() not
implemented
mahoneyd at unbc.ca
mahoneyd at unbc.ca
Tue Nov 9 00:25:20 EST 2004
Thanks, that fixed it. Does anyone know why shared libraries no longer
work? They were fine before I reinstalled Mac OS (and updated the grass
sources from CVS).
Dave
> Hi,
> We have the same problem on Cygwin in terms of the db error. You may
> want to configure with --disable-shared.
> ./configure --disable-shared
> make
> Hope this helps.
> Huidae Cho
> On Sun, 07 Nov 2004 19:08:13 -0800, David Mahoney <mahoneyd at unbc.ca>
> wrote:
>> Hi,
>> I am running Mac OS X (10.2.8) and have compiled grass 5.7 (cvs).
>> However, when I run v.in.ogr, I get this error
>> GRASS 5.7.cvs:~/gisdata/grass_x/93f/93f037 > v.in.ogr dsn=tctr_037 \
>> layer=LAB,ARC type=line out=tctr_037
>> A datum name nad83 (North_American_Datum_1983) was specified without
>> transformation parameters.
>> WARNING: Non-interactive mode: the GRASS default for nad83 is
>> towgs84=0.000,0.000,0.000.
>> Projection of input dataset and current location appear to match.
>> Proceeding with import...
>> WARNING: The vector 'tctr_037' already exists and will be overwritten.
>> dbmi: db_open_database() not implemented
>> WARNING: Cannot open database
>> '/Users/dave/gisdata/grass/trim-utm10/dave/dbf'
>> '/Users/dave/gisdata/grass/trim-utm10/dave/dbf' by driver
>> 'dbf'
>> WARNING: Cannot get info if table 'tctr_037_1' linked to vector exists.
>> ERROR: Cannot delete existing vector tctr_037
>> Is this a GDAL problem?
>> Thanks,
>> Dave
