[GRASSLIST:4816] problem compiling Grass 5.7.0
    Allard, Yannick (EXP)
    yannick.allard at lmco.com
    Fri Nov 12 16:43:36 EST 2004
Hi everyone,
I'm trying to compile Grass 5.7.0 on solaris2.9 intel architecture, however I have sevral problems. At first, I have many Unexpected end of line in the different Makefiles where there is some ifeq (...) or ifndef. However the syntax is correct. I have just removed those parts since they were not necessary for what I'm trying to do. Some where referring to OpenGL or checking if GRASS_LIBRARY_TYPE was stlib.
make: Fatal error in reader: ../include/Make/Grass.make, line 236: Unexpected end of line seen
Current working directory /home/yallard/GRASS/grass-5.7.0/lib
gnumake: *** [default] Error 1
~/GRASS/grass-5.7.0 % gnumake
make: Fatal error in reader: ../include/Make/Rules.make, line 9: Unexpected end of line seen
make: Fatal error in reader: Makefile, line 38: Unexpected end of line seen
Now I have the following error :
if [ ! -d /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include ]; then mkdir -p /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include; fi
if [ ! -d /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/vect ]; then mkdir -p /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/vect; fi
install -m 644 ../include/*.h /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/
find: cannot read dir /etc/inet/secret: Permission denied
find: cannot read dir /etc/sfw/private: Permission denied
install: CC.h was not found anywhere!
gnumake: *** [headers] Error 2
CC.h is in the ../include/*.h directory, but it is not finding it. I'm using gcc 3.3.2.
Anyone knows what to do?
Thanks in advance
Yannick
Yannick Allard
Ph.D student, Universite de Sherbrooke
