[GRASSLIST:4841] Re: problem compiling Grass 5.7.0
David Mahoney mahoneyd at unbc.ca
Mon Nov 15 14:09:35 EST 2004
Did you make sure that you are indeed using GNU make and not the make
that comes with Solaris?
Dave
On Fri, 12 Nov 2004, Allard, Yannick (EXP) wrote:
> Hi everyone,
> I'm trying to compile Grass 5.7.0 on solaris2.9 intel architecture, however I have sevral problems. At first, I have many Unexpected end of line in the different Makefiles where there is some ifeq (...) or ifndef. However the syntax is correct. I have just removed those parts since they were not necessary for what I'm trying to do. Some where referring to OpenGL or checking if GRASS_LIBRARY_TYPE was stlib.
> make: Fatal error in reader: ../include/Make/Grass.make, line 236: Unexpected end of line seen
> Current working directory /home/yallard/GRASS/grass-5.7.0/lib
> gnumake: *** [default] Error 1
> ~/GRASS/grass-5.7.0 % gnumake
> make: Fatal error in reader: ../include/Make/Rules.make, line 9: Unexpected end of line seen
> make: Fatal error in reader: Makefile, line 38: Unexpected end of line seen
> Now I have the following error :
> if [ ! -d /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include ]; then mkdir -p /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include; fi
> if [ ! -d /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/vect ]; then mkdir -p /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/vect; fi
> install -m 644 ../include/*.h /home/yallard/GRASS/grass-5.7.0/dist.i386-pc-solaris2.9/include/
> find: cannot read dir /etc/inet/secret: Permission denied
> find: cannot read dir /etc/sfw/private: Permission denied
> install: CC.h was not found anywhere!
> gnumake: *** [headers] Error 2
> CC.h is in the ../include/*.h directory, but it is not finding it. I'm using gcc 3.3.2.
> Anyone knows what to do?
> Thanks in advance
> Yannick
> Yannick Allard
> Ph.D student, Universite de Sherbrooke
Dave
