[GRASSLIST:4830] Re: Problems importing Data into lat/lon with
negtiv south value
Stephan Holl
sholl at gmx.net
Sun Nov 14 13:31:48 EST 2004
Hello Paul,
On Sun, 14 Nov 2004 11:55:34 +0000 (GMT) Paul Kelly
<paul-grass at stjohnspoint.co.uk> wrote:
> On Sun, 14 Nov 2004, Stephan Holl wrote:
> > Dear Users,
> > I am trying to import some MODIS data into GRASS. In a first step I
> > managed to convert a subdataset of the MODIS data into img-format
> > using gdal_translate.
> > The dataset is a global dataset which should be in lat/long.
> > The problem seems to be with negative south and west values, as
> > GRASS needs south boundaries as 90S and not -90 (as my data have).
> > Is there a solution to use this kind of data in GRASS? Thanks for
> > any pointers on this topic.
> What actually is the problem? Did something go wrong when you tried to
> import it into GRASS? Was this using r.in.gdal? And which GRASS
> version?
yes, r.in.gdal did not work, because latitude for south was illigal.
Proceeding with import...
WARNING: G_set_window(): Illegal latitude for South
no map is imported.
thanks for any hints.
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20041114/1e389c77/attachment.bin
