[GRASSLIST:4850] Compilation of GRASS 5.7
Praktikant praktikant at ib-net.net
Tue Nov 16 11:30:00 EST 2004
Hello,
I just compiled and installed GRASS5.7. under cygwin.
My configure command: ./configure --with-postgres=no --with-odbc=no
When I start grass57 -tcltk I get the following error message:
 Error in startup script: couldn't execute "ps.map": no such file or
directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-5.7.cvs/etc/dm/d.m.tcl" line 874)
After pressing ENTER I can start a monitor and open raster datasets but when
I try to display a vector file with d.vect I got:
"command not found"
Then I checked the error.log and found a whole bunch of errors (see below).
Can anybody help me with that?
Thank you for suggestions
Richard
error.log
GRASS GIS compilation log
Started compilation: Tue Nov 16 14:08:23     2004
Errors in:
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/vector/Vlib
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/sites
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/rst/interp_float
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/ogsf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/db/drivers/ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.path
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.vect.chart
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.what.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.where
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/display/d.zoom
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.region/cmd
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g3.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/g.setproj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/general/manage/cmd
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/imagery/i.vpoints
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/ps/ps.map
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.contour
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.cost
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.flow
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.le/r.le.setup
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.random
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.resamp.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.sun
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.sunmask
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.to.vect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster/r.in.gdal
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/raster3d/r3.showdspf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.buffer
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.build
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.build.polylines
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.category
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.clean
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.convert
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.database
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.db.connect
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.digit
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.distance
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.extract
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.hull
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.info
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.ascii
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.db
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.region
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.sites
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.kcv
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.kernel
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.label
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.proj
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.mkgrid
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.neighbors
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.alloc
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.iso
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.path
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.salesman
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.net.steiner
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.normal
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.ascii
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.dxf
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.pov
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.overlay
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.patch
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.perturb
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.qcount
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.random
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.reclass
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.sample
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.segment
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.select
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.surf.idw
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.surf.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.transform
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.db
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.points
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.to.rast
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.type
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.univar
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.voronoi
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.what.rast
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.vol.rst
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.out.ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.in.ogr
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/vector/v.external
/home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/visualization/nviz
Finished compilation: Tue Nov 16 14:45:00     2004
