[GRASSLIST:4854] Re: Compilation of GRASS 5.7
Tue Nov 16 12:53:18 EST 2004
Praktikant wrote:
> I just compiled and installed GRASS5.7. under cygwin.
> Then I checked the error.log and found a whole bunch of errors (see below).
> Can anybody help me with that?
> GRASS GIS compilation log
> Started compilation: Tue Nov 16 14:08:23     2004
> Errors in:
> /home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/proj
> /home/Praktikant/tmp/Grass57/grass57_exp_2004_11_13/lib/vector/Vlib
Both of these errors are critical, in that they will result in many
necessary programs failing to compile.
You need to examine the output from "make" to determine why the
compilation failed.
