[GRASSLIST:4889] Re: Using FileMaker Pro 7.0 as a DBMS
    Michael Barton
    michael.barton at asu.edu
    Sat Nov 20 12:37:14 EST 2004
Kurt,
I would strongly recommend 5.7 over 5.4 to do this. Built-in ODBC driver so
you don't have to set it up manually.
I think the problem with the tcltk startup failing in the creation of a new
location has been solved. Good luck.
Michael Barton
On 11/19/04 10:27 PM, "Kurt Springs" <ferret_bard at mac.com> wrote:
> I am going to attempt to use FileMaker Pro 7.0 tomorrow.  Will it be
> better to use 5.4 or 5.7?  Also, does 5.4 suffer from the same problem
> as earlier versions did when you tried to create a new Project in
> Graphical mode?  (I.e. the tcltkgrass interface fails.)  Should I create
> the new project in text mode, or will it be safe to do it in graphical mode.
> Wish me luck.  I will keep everyone posted.
> Kurt D. Springs, M.Litt
> University at Buffalo
> Social Systems GIS Laboratory
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
