[GRASSLIST:4905] Re: libogdi31.so
Paolo Cavallini cavallini at faunalia.it
Tue Nov 23 02:34:39 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Note however that this is the first time we see that problem.
With previous GRASS versions everythig's ok.
GRASS form binaries (not compiled) on a Debian Sarge box, with GDAL from
Debian package.
Markus, perhaps something went wrong during the compilation?
Thanks.
pc
At 02:45, martedì 23 novembre 2004 you presumably wrote:
> Sandro Klippel wrote:
> > > > installing the new version of GRASS (20-11) I see that there is a new
> > > > needed library (libogdi31.so) that is available only for Mandrake.
> > > > Is it a truly needed library or only a bug in the binary of the week?
> > > Probably the latter. Which programs/libraries require it?
> > GDAL compiled with OGDI.
> In that case, it should only be an issue for the GDAL library. Delete
> the libgdal binary which came with GRASS (from $GISBASE/lib) and
> install one which is compatible with your system.
> Given the large number of possible dependencies for GDAL, the chances
> of a libgdal binary built for one system is working on another system
> are low. It doesn't help that GDAL's configure script insists on
> autodetecting everything; you have to explicitly provide --without-*
> switches for any libraries which you don't want to use.
> Probably the simplest solution is to either build GDAL yourself from
> source code, or install your OS vendor's "official" GDAL package (if
> they have one), along with all of the necessary dependencies (package
> management tools such as RPM will either do this for you or at least
> tell you what you need to install).
Paolo Cavallini
cavallini at faunalia.it   www.faunalia.it   www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBougP/NedwLUzIr4RArqAAJ90iaRR9phvlGPS8JSKyKoEQ2VfZACdFb2+
2fULFaKIb139QGUws2CNzKM=
=72a8
-----END PGP SIGNATURE-----
