[GRASSLIST:4953] Re: Problems importing Data into lat/lon with
negtiv south value
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Nov 25 04:30:37 EST 2004
On Tue, 16 Nov 2004, Glynn Clements wrote:
> Paul Kelly wrote:
>> I don't disagree that this is the actual behaviour, but on reading though
>> the source code it seems to me this wasn't the intended behaviour and it
>> is trying to write out the bounds of the imported map as the current
>> region (i.e WIND). But G_set_window() doesn't change anything because of
>> some caching it does or something (I looked into it a long time ago and
>> don't remember all the details now).
>> Unless I'm misunderstanding what G_set_window() is supposed to do but I
>> think it's for setting the current region.
> G_set_window() sets the process' internal region (i.e. G__.window),
> not the WIND file. It doesn't modify the WIND file, and isn't meant
> to.
> If you want to set the mapset's current region (i.e. the WIND file),
> you need to use G_put_window(). If you want to modify some other file
> (i.e. PERMANENT/DEFAULT_WIND or a cellhd file), you need to use
> G__put_window().
Right; get you there.
> I'm fairly certain that r.in.gdal's behaviour (both with and without
> the -e flag) is intentional.
I wonder then why it doesn't just extend the current region, as (as I
understand it) can be done reliably because the current user definitely
has permission to change it, rather than extending the default.
>> If you are using v.in.ogr to create a new location based on the projection
>> of the vector map being imported, it has to create a DEFAULT_WIND, and it is
>> good to populate it with meaningful region extents, which can be got through
>> some OGR function (get extents or something like that).
> Right; if you're creating a new location, it makes sense.
I don't think the -e flag is working in v.in.ogr. If I get a chance
sometime I will try and update it to extend the current region, or perhaps
it could be removed as regions aren't so relevant for vectors (should they
be?)
Paul
