[GRASSLIST:4957] Re: Problems importing Data into lat/lon with negtiv south value
Thu Nov 25 06:09:28 EST 2004
Paul Kelly wrote:
> > I'm fairly certain that r.in.gdal's behaviour (both with and without
> > the -e flag) is intentional.
> I wonder then why it doesn't just extend the current region, as (as I
> understand it) can be done reliably because the current user definitely
> has permission to change it, rather than extending the default.
Yeah, I thought that too.
Maybe it's because you can extend the current region yourself with
"g.region rast=...", but g.region doesn't allow you to change the
default region (which is a pretty major deficiency, IMHO).
