[GRASSLIST:5000] Re: [GRASS5] v.patch in 5.7 problems
Radim Blazek
blazek at itc.it
Tue Nov 30 04:07:55 EST 2004
Maciek Sieczka wrote:
> From: "Radim Blazek" <blazek at itc.it>
>>> grass57_exp_2004_11_13
>>> After merging a vector consisted of points with a vector consisted of
>>> lines using v.patch I get a file where some lines and points are
>>> assigned the same "field:" and "category:". It unables me create a
>>> database which would assign the elevation values to both points and
>>> contour lines at one time! And I need it to be done so in order to
>>> interpolate this "merged" elevation information in one turn with
>>> v.surf.rst. Both input files had a nice database.
>>> BTW - why doesn't the v.patch create a merged database for the output
>>> file while in 5.5 the v.patch copies all the input's cats and labels
>>> to the output?
>>> Please somebody answer and let me know if it's a bug worthy of a bug
>>> report.
>> It is wish report.
> Thanks for the reply.
> After re-thinking my problem I'd say that it should rather be a regular
> bug - in my opinion in one vector file there may not be two diffrent
> features having the same "field:" and "category:" which happens when
> using v.patch. Am I wrong?
Both can be useful, preserve cats or assign new unique cats.
Ideally v.patch should support both. A Bug is if it does not do what it
should - what is written in man. A wish is if a feature is missing.
Radim
