[GRASSLIST:5009] Re: Still having database trouble.
Kurt Springs
ferret_bard at mac.com
Tue Nov 30 21:58:32 EST 2004
Filemaker has the ability to import through odbc, but not to export.
Kurt
Nick Cahill wrote:
> Good luck with this. I did get the database link to work with an
> older version of 5.7. I think that I started by importing a vector
> file (a dxf or microstation dgn file), then created and connect to a
> new dbf database using v.digit. Then, once the database was created
> within GRASS and linked, I modified the dbf file in some dbf program
> (in fact, I think I imported it into Filemaker, modified it there,
> and then reexported it, replacing the original dbf file). This was
> clearly not the way one should have to do things. I've got to say, I
> used to do this sort of thing using ArcView, simply linking databases
> to geographic data, and it was completely easy and transparent there.
> I wish it were easier in GRASS.
> I would still much prefer to connect directly with the filemaker
> databases. Were you able to set up Filemaker as an odbc source?
> Good luck,
> Nick
