[GRASSLIST:4480] Re: How can I speed this up?
Wed Oct 6 23:06:24 EDT 2004
> The code is very simple:
> for MYCAT in `echo "select distinct avicat from
> allpoly_att"|db.select
> -c`;  do
>     echo $MYCAT
>     AGE=`echo "select age from play_att where link_key = $MYCAT" |
> db.select -c`
>     COVER=`echo "select cover from play_att where link_key = $MYCAT"
> db.select -c`
>     echo "update allpoly_att set age = $AGE where avicat = $MYCAT" |
> db.execute
>     echo "update allpoly_att set cover = $COVER where avicat =
> $MYCAT" |
> db.execute
> done
> Right now, it is doing about 2 updates per second - which is too
> slow!
> Is the slowness caused by piping it through db.execute?
> Other suggestions for speeding this up?
you might scatter in the "date" unix command in to show a timestamp or
use the "time" command ('time db.execute ...') to profile which command
is the slow link.
Hamish
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
