[GRASSLIST:4501] Re: How can I speed this up?
    Radim Blazek
    blazek at itc.it
    Mon Oct 11 04:52:38 EDT 2004
On Thursday 07 October 2004 00:03, Craig Aumann wrote:
> The code is very simple:
> for MYCAT in `echo "select distinct avicat from allpoly_att"|db.select
> -c`;  do
>     echo $MYCAT
>     AGE=`echo "select age from play_att where link_key = $MYCAT" |
> db.select -c`
>     COVER=`echo "select cover from play_att where link_key = $MYCAT" |
> db.select -c`
>     echo "update allpoly_att set age = $AGE where avicat = $MYCAT" |
> db.execute
>     echo "update allpoly_att set cover = $COVER where avicat = $MYCAT" |
> db.execute
> done
> Right now, it is doing about 2 updates per second - which is too slow!
> Is the slowness caused by piping it through db.execute?
> Other suggestions for speeding this up?
Postgres + index for link_key and avicat.
Radim
