[GRASSLIST:4485] Re: create a network
Markus Neteler
neteler at itc.it
Thu Oct 7 10:06:12 EDT 2004
On Tue, Sep 21, 2004 at 03:31:48PM +0200, Radim Blazek wrote:
> On Tuesday 21 September 2004 11:02, Leonardo Lami wrote:
> > Hi,
> > I have an area polygonal vector and I'd like to create a network between
> > its elemnts. It is possible to create a network where the linking lines are
> > the minimum distances between the boundaries of the nodes?
> > Thanks to all the list
> Not sure if it is what you want, I have a module doing this
> (the red line generated from green+blue):
> http://mpa.itc.it/radim/g51/v.area.path.png
> It is not finished, I can send it to you, but without any additional support.
> Radim
Just for the record:
v.voronoi
Description:
Create a Delaunay triangulation from an input vector of points or centroids.
now in 5.7 thanks to Radim.
Markus
