[GRASSLIST:4486] Re: DEMPSTER-SHAFER modelling
benducke at compuserve.de
Thu Oct 7 12:23:02 EDT 2004
The modules should compile fine on 5.0, but really,
5.3 is much better than 5.0 and you should upgrade.
5.7 has a different vector architecture and that
caused a lot of modules to break or become obsolete.
A switch from 5.0 to 5.3 should not make anything worse.
When I get back home I will look into the possibility
of suplying ready-to-install binary modules that you
just have to copy into your GRASS 5 bin tree.
I would then upload the stuff to Michael's website
if that is alright.
Cheers,
Benjamin.
----- Originalnachricht -----
Von: Chavoux Luyt <educluyt at sun.ac.za>
Datum: Mittwoch, 6. Oktober 2004 10:07 pm
Betreff: Re: [GRASSLIST:4473] Re: DEMPSTER-SHAFER modelling
> Thanks Benjamin!
> I suppose I'll just have to wait then.
> Now for a stupid question: I have both GRASS 5.0.3 and GRASS 5.7
> installed (but not GRASS 5.3). Do you think I'll be able to use
> the
> modules with them?
> To my shame (I really haven't had time), I have never looked at
> the
> source code of GRASS at all (so far I have just "apt-get install"
> the
> binary .deb packages). As I understand it, GRASS consists of a
> number of
> seperate executables that can be called either from the command
> line or
> from tcl/tk and that the initial "grass" program just set up the
> environment so that these executables become available on the
> current
> path. In that case will I really need to recompile grass? (I don't
> mind
> if there is no GUI available for the modules as long as there is
> enough
> help files).
> I'm just scared of breaking a working system when I recompile (and
> I'm
> quite pressed for time). I already found that some modules working
> perfectly in GRASS 5.0.3 weren't working in GRASS 5.7 and that is
> why I
> have both installed (and use both: GRASS 5 for most raster and 3D
> stuff
> and GRASS 5.7 for most of the vector and database stuff).
> In any case, it will be greatly appreciated if you could e-mail
> them to
> me. If might be good if you also e-mailed them to my yahoo e-mail,
> because sometimes the University e-mail server refuse large e-
> mails. It
> is: Chavoux at yahoo.com
> Thanks for all the trouble. Enjoy Egypt !
> Greetings
> Chavoux
> benducke at compuserve.de wrote:
> >I wrote those modules a little while ago.
> >They work fine with GRASS 5.3 and can,
> >in principle be used for any sort of predictive model.
> >My plan is to adapt the code for GRASS 5.7 and commit
> >it to the CVS version.
> >I have no homepage or any place to distribute the current
> >version, but will email it to you if you want it.
> >Unfortunately, I am in Egypt right now and have no
> >access to my progs.
> >You will have to wait until I get back home at the
> >start of November.
> >You will also have to compile the modules yourself and
> >add them to your GRASS 5.3 installation.
> >Cheers,
> >Benjamin
> >Datum: Mittwoch, 6. Oktober 2004 5:13 pm
> >Betreff: [GRASSLIST:4473] Re: DEMPSTER-SHAFER modelling
> >>Hi
> >>Some time ago I read about a GRASS module for archeological
> >>modelling
> >>using the DEMPSTER-SHAFER method. It had a link to an ESRI
> webpage
> >>describing the method, but used in habitat analysis on ArcView.
> I
> >>would
> >>like to know if the GRASS module can also be used for this
> purpose
> >>(predicting occurence of animals from habitat factors) instead
> of
> >>for
> >>archeology. Unfortunately I can't remember the author of the
> >>module (I
> >>didn't at the time think it would be usefull for my puposes).
> >>Any help will be appreciated.
> >>Chavoux Luyt
