[GRASSLIST:4499] Re: shapefile vs SDTS : which is recommendable?
Hamish
hamish_nospam at yahoo.com
Sun Oct 10 02:25:53 EDT 2004
> I was just wonderng:
> Which dataset format would be recommendable, given both SDTS and
> Shapefile as possible options?
GRASS 5.7 + v.in.ogr or v.external works really well for Shape files.
5.7's v.in.ogr or v.external should work on SDTS files as well, I
couldn't tell you which format would work better, only that the shape
files are probably the better tested format.
http://gdal.org/ogr/ogr_formats.html
Again for emphasis, 5.7 is the way to go if you are working with vector
data.
Hamish
