[GRASSLIST:4600] Re: Error loading libgdal.so.1
    Miha Staut
    mihastaut at yahoo.co.uk
    Thu Oct 21 09:20:03 EDT 2004
> Hi!
> The compilation of the fresh GRASS 5.7 distribution
> on my Fedora core 2 terminated without problems (not
> counting an r3 command). But soon after running
> grass57 I encountered the following problem.
> d.vect: error while loading shared libraries:
> libgdal.so.1: cannot open shared object file: No
> such > file or directory
> The same compilation procedure worked fine some time
> ago (... --with-gdal=/usr/local/bin/gdal-config).
> Are > there any special reasons?
> Thanks, Miha Staut
I found the following message in the mailing list
archive:
[GRASSLIST:3591] Re: error find libgdal.so.1 on
grass57
On Thursday 03 June 2004 19:46, Didit Ahendra wrote:
> hi all,
> my GRASS 5.7 that I just install have error.
> If I write grass command for example g.list or
d.vect
> there is can't find libgdal.so.1
> error display like this:
> GRASS 5.7.-cvs:~ > g.list
> g.list: error while loading shared libraries:
such
> file or directory
> I don't find this file in my
> library directory although I had installed
> libgdal0-1.1.9-2mdk.i586.rpm
> I only find libgdal.1.1.so in /usr/lib
> would anybody help me to solve my problem,please?
> I'm waiting for your help.Thank's before.
Make a symbolic link
ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1
Radim
Thanks anyway, Miha
___________________________________________________________ALL-NEW Yahoo! Messenger - all new features - even more fun!  http://uk.messenger.yahoo.com
