[GRASSLIST:4608] Re: Error loading libgdal.so.1
    Markus Neteler
    neteler at itc.it
    Fri Oct 22 05:10:15 EDT 2004
Miha,
On Thu, Oct 21, 2004 at 11:53:49AM +0100, Miha Staut wrote:
> Hi!
> The compilation of the fresh GRASS 5.7 distribution on
> my Fedora core 2 terminated without problems (not
> counting an r3 command). But soon after running
> grass57 I encountered the following problem.
> d.vect: error while loading shared libraries:
> libgdal.so.1: cannot open shared object file: No such
> file or directory
> The same compilation procedure worked fine some time
> ago (... --with-gdal=/usr/local/bin/gdal-config). Are
> there any special reasons for this change? I am using
> gdal-1.2.1.
Here is what the GDAL developers recommends:
 http://xserve.flids.com:16080/pipermail/gdal-dev/2004-October/007360.html
 "1.2.1?  That is ancient. ... "
Maybe worth an update.
 Markus
